Salta al contenuto principale
LG L1200 Keypad Replacement
Cosa ti serve
  1. LG L1200 Keypad Replacement, Logic Board: passo 1, immagine 1 di 1
    • Make sure you remove the battery by lifting the tab on the back of the phone before opening the case.
    • Poke out rubber covers using a spudger or pointy object, such as a thumb tack.
  2. LG L1200 Keypad Replacement: passo 2, immagine 1 di 1
    • Use a T6 torx screwdriver to unscrew the 6 screws that hold the back casing on.
  3. LG L1200 Keypad Replacement: passo 3, immagine 1 di 1
    • Use IPod opening tool to separate back housing.
    • There are two tabs located on either side of the phone.
  4. LG L1200 Keypad Replacement: passo 4, immagine 1 di 1
    • Separate the back housing from the phone.
    • Be careful not to rip out the wire (highlighted in yellow) when separating the back housing.
  5. LG L1200 Keypad Replacement: passo 5, immagine 1 di 1
    • Use a spudger to disconnect antenna wire.
  6. LG L1200 Keypad Replacement: passo 6, immagine 1 di 1
    • Use the IPod opening tool to pop out the logic board.
  7. LG L1200 Keypad Replacement: passo 7, immagine 1 di 1
    • Use the IPod opening tool to disconnect the main ribbon.
  8. LG L1200 Keypad Replacement: passo 8, immagine 1 di 1
    • Once the ribbon is detached, remove the logic board and replace if necessary.
  9. LG L1200 Keypad Replacement, Keypad: passo 9, immagine 1 di 1
    • The back of the keypad is shown here, next to the logic board (the logic board is turned over to expose the buttons).
  10. LG L1200 Keypad Replacement: passo 10, immagine 1 di 2 LG L1200 Keypad Replacement: passo 10, immagine 2 di 2
    • Using a spudger, lift the keypad off of the tabs.
Conclusione
Cal Poly, Team 6-14, Maness Spring 2010 Membro di Cal Poly, Team 6-14, Maness Spring 2010
CPSU-MANESS-S10S6G14
4 Membri
16 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 27
Tutti i Tempi: 1,219
