Salta al contenuto principale
LG KP100 SIM Card Replacement
  1. LG KP100 SIM Card Replacement, Battery: passo 1, immagine 1 di 2 LG KP100 SIM Card Replacement, Battery: passo 1, immagine 2 di 2
    • Begin by taking the back battery cover off.
    • Put your index finger on the white notch and apply pressure.
    • While applying pressure, move your hand backwards to slide the battery cover off of the body of the phone.
  2. LG KP100 SIM Card Replacement: passo 2, immagine 1 di 2 LG KP100 SIM Card Replacement: passo 2, immagine 2 di 2
    • Remove the battery.
    • Put your index finger in the notch above the battery near the top of the casing.
    • While applying pressure against the battery, lift up and take out the battery.
  3. LG KP100 SIM Card Replacement, SIM Card: passo 3, immagine 1 di 3 LG KP100 SIM Card Replacement, SIM Card: passo 3, immagine 2 di 3 LG KP100 SIM Card Replacement, SIM Card: passo 3, immagine 3 di 3
    • Remove the SIM card from its housing.
    • Put your finger in the provided notch below the SIM card and begin to push the SIM card towards the top of the device.
    • After it is out of the metal housing, it is free to be removed.
Conclusione
Cal Poly, Team 6-20, Amido Spring 2012 Membro di Cal Poly, Team 6-20, Amido Spring 2012
CPSU-AMIDO-S12S6G20
4 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 17
Tutti i Tempi: 1,298
