Salta al contenuto principale
LG K7 Volume & On/Off Buttons Replacement
Cosa ti serve
  1. LG K7 Volume & On/Off Buttons Replacement, Volume & On/Off Buttons: passo 1, immagine 1 di 2 LG K7 Volume & On/Off Buttons Replacement, Volume & On/Off Buttons: passo 1, immagine 2 di 2
    • Remove the back cover using a plastic opening tool.
    • Remove the battery using a plastic opening tool.
  2. LG K7 Volume & On/Off Buttons Replacement: passo 2, immagine 1 di 1
    • Remove the nine 4mm Phillips #000 screws.
    • The cover should lift off easily once the screws are out.
    • Be gentle with the frame when removing it. The plastic is very thin and can easily break.
  3. LG K7 Volume & On/Off Buttons Replacement: passo 3, immagine 1 di 1
    • Pry off the silver button housing using the plastic opening tool.
  4. LG K7 Volume & On/Off Buttons Replacement: passo 4, immagine 1 di 1
    • Separate the screen from the rest of the phone using the plastic opening tool.
    • The frame is held to the rest of the phone with plastic tabs. Release each tab one at a time around the phone for the easiest removal.
    • Do not bend the outer frame or screen when separating them. This will severely damage the phone.
  5. LG K7 Volume & On/Off Buttons Replacement: passo 5, immagine 1 di 3 LG K7 Volume & On/Off Buttons Replacement: passo 5, immagine 2 di 3 LG K7 Volume & On/Off Buttons Replacement: passo 5, immagine 3 di 3
    • Peel off the orange cable using a plastic opening tool.
  6. LG K7 Volume & On/Off Buttons Replacement: passo 6, immagine 1 di 1
    • Remove the volume/power button cable from the rest of the phone using the plastic opening tool to break the adhesive.
Conclusione
Jack Lepkowski
Membro da: 11/07/19
136 Reputazione
1 Guida realizzata
IUPUI, Team S3-G2, Harley Fall 2019 Membro di IUPUI, Team S3-G2, Harley Fall 2019
IUPUI-HARLEY-F19S3G2
3 Membri
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 578
