Introduzione
This is guide will demonstrate how to remove the motherboard from a LG-K7. The motherboard has numerous of components connecting to it and user should be careful while removing these component so the main board doesn't get damage.
Cosa ti serve
Flip the LG K7 over so that the back of the phone is facing up.
Locate the small notch on the bottom left side of the phone.
Located to nine 3.4 mm screws that keep that keep the phones rear housing in tacked.
Using a Phillips 00 screwdriver remove all nine 3.4 mm screws.
Locate the ribbon for the front facing camera.
Carefully remove the front facing camera's ribbon cable from the motherboard using the plastic removal tool.
Holding the front camera ribbon you just released pull upwards and the camera should release from the case.
Remove the band that connects the screen display to the motherboard.
Wedge a plastic opening tool between the motherboard and the phones casing.
While using one finger to hold down a portion of the phone pull upwards with the plastic opening tool to loosen the motherboard from the phone casing.
Once there is some space between the board and the phone case, using your hands carefully lift the motherboard from the phone casing.
Altre 7 persone hanno completato questa guida.
