Salta al contenuto principale
LG K7 T-Mobile Motherboard Replacement
Cosa ti serve
  1. LG K7 T-Mobile Motherboard Replacement, Battery: passo 1, immagine 1 di 2 LG K7 T-Mobile Motherboard Replacement, Battery: passo 1, immagine 2 di 2
    • Flip the LG K7 over so that the back of the phone is facing up.
    • Locate the small notch on the bottom left side of the phone.
  2. LG K7 T-Mobile Motherboard Replacement: passo 2, immagine 1 di 1
    • Insert a plastic opening tool into the notch and lift the back cover upward while holding the bottom portion of the phone down to remove it.
  3. LG K7 T-Mobile Motherboard Replacement: passo 3, immagine 1 di 1
    • Remove the battery.
  4. LG K7 T-Mobile Motherboard Replacement, Motherboard: passo 4, immagine 1 di 2 LG K7 T-Mobile Motherboard Replacement, Motherboard: passo 4, immagine 2 di 2
    • Located to nine 3.4 mm screws that keep that keep the phones rear housing in tacked.
    • Using a Phillips 00 screwdriver remove all nine 3.4 mm screws.
  5. LG K7 T-Mobile Motherboard Replacement: passo 5, immagine 1 di 3 LG K7 T-Mobile Motherboard Replacement: passo 5, immagine 2 di 3 LG K7 T-Mobile Motherboard Replacement: passo 5, immagine 3 di 3
    • Turn the phone over so the screen is facing up.
    • Insert your plastic opening tool between the midframe and front panel assembly on the side of the phone.
    • Slide the plastic opening tool down the seams carefully to separate the screen from the rest of the phone housing.
  6. LG K7 T-Mobile Motherboard Replacement: passo 6, immagine 1 di 3 LG K7 T-Mobile Motherboard Replacement: passo 6, immagine 2 di 3 LG K7 T-Mobile Motherboard Replacement: passo 6, immagine 3 di 3
    • Locate the lock that holds the camera's ribbon cable in place.
    • Carefully remove the camera's ribbon cable from the motherboard using the plastic removal tool.
    • Holding the camera ribbon you just released pull upwards and the camera should release from the case.
  7. LG K7 T-Mobile Motherboard Replacement: passo 7, immagine 1 di 2 LG K7 T-Mobile Motherboard Replacement: passo 7, immagine 2 di 2
    • Locate the headphone jack towards the bottom right of the phone.
    • Place a plastic removal tool underneath the head phone jack.
    • Lift the plastic removal tool upward to remove the earphone jack from the phone case.
  8. LG K7 T-Mobile Motherboard Replacement: passo 8, immagine 1 di 2 LG K7 T-Mobile Motherboard Replacement: passo 8, immagine 2 di 2
    • Locate the ribbon for the front facing camera.
    • Carefully remove the front facing camera's ribbon cable from the motherboard using the plastic removal tool.
    • Holding the front camera ribbon you just released pull upwards and the camera should release from the case.
    • Remove the band that connects the screen display to the motherboard.
  9. LG K7 T-Mobile Motherboard Replacement: passo 9, immagine 1 di 2 LG K7 T-Mobile Motherboard Replacement: passo 9, immagine 2 di 2
    • Locate the ribbon cable that connects the screen to the motherboard.
    • Carefully remove the screen's ribbon cable from the motherboard using the plastic removal tool by lifting the ribbon cable upwards.
  10. LG K7 T-Mobile Motherboard Replacement: passo 10, immagine 1 di 3 LG K7 T-Mobile Motherboard Replacement: passo 10, immagine 2 di 3 LG K7 T-Mobile Motherboard Replacement: passo 10, immagine 3 di 3
    • Wedge a plastic opening tool between the motherboard and the phones casing.
    • While using one finger to hold down a portion of the phone pull upwards with the plastic opening tool to loosen the motherboard from the phone casing.
    • Once there is some space between the board and the phone case, using your hands carefully lift the motherboard from the phone casing.
Conclusione
Altre 7 persone hanno completato questa guida.
Brandon Jones
Membro da: 09/28/17
233 Reputazione
1 Guida realizzata
USF Tampa, Team S2-G5, Nance Fall 2017 Membro di USF Tampa, Team S2-G5, Nance Fall 2017
USFT-NANCE-F17S2G5
3 Membri
8 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 11
Tutti i Tempi: 2,197
