Salta al contenuto principale
LG K7 T-Mobile Back Controls Replacement
Cosa ti serve
  1. LG K7 T-Mobile Back Controls Replacement, Battery: passo 1, immagine 1 di 2 LG K7 T-Mobile Back Controls Replacement, Battery: passo 1, immagine 2 di 2
    • Flip the LG K7 over so that the back of the phone is facing up.
    • Locate the small notch on the bottom left side of the phone.
  2. LG K7 T-Mobile Back Controls Replacement: passo 2, immagine 1 di 1
    • Insert a plastic opening tool into the notch and lift the back cover upward while holding the bottom portion of the phone down to remove it.
  3. LG K7 T-Mobile Back Controls Replacement: passo 3, immagine 1 di 1
    • Remove the battery.
  4. LG K7 T-Mobile Back Controls Replacement, Back Controls: passo 4, immagine 1 di 2 LG K7 T-Mobile Back Controls Replacement, Back Controls: passo 4, immagine 2 di 2
    • Locate the screw keeping the back controls in place.
    • Use a Phillips 00 screwdriver to remove the 3.4 mm screw.
  5. LG K7 T-Mobile Back Controls Replacement: passo 5, immagine 1 di 1
    • Using the plastic opening tool create a space between the chrome bezel of the back buttons and the phone's casing.
    • Using the plastic opening tool pry the back buttons upward to remove them from the phone's casing.
Conclusione
Nam Pham
Membro da: 09/28/17
201 Reputazione
2 Guide realizzate
USF Tampa, Team S2-G5, Nance Fall 2017 Membro di USF Tampa, Team S2-G5, Nance Fall 2017
USFT-NANCE-F17S2G5
3 Membri
8 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 8
Tutti i Tempi: 534
