Salta al contenuto principale
LG K7 Rear Facing Camera Replacement
Cosa ti serve
  1. LG K7 Rear Facing Camera Replacement, Battery: passo 1, immagine 1 di 2 LG K7 Rear Facing Camera Replacement, Battery: passo 1, immagine 2 di 2
    • Place a fingernail in slot at in the bottom edge of the phone.
    • Pull up on the back panel while holding down the rest of the phone steady with your hand.
    • Do not to pull too hard on the back panel or you may break it.
  2. LG K7 Rear Facing Camera Replacement: passo 2, immagine 1 di 2 LG K7 Rear Facing Camera Replacement: passo 2, immagine 2 di 2
    • Place a fingernail in the slot at the bottom edge of the battery.
    • Pull the battery out.
  3. LG K7 Rear Facing Camera Replacement, Rear Facing Camera: passo 3, immagine 1 di 3 LG K7 Rear Facing Camera Replacement, Rear Facing Camera: passo 3, immagine 2 di 3 LG K7 Rear Facing Camera Replacement, Rear Facing Camera: passo 3, immagine 3 di 3
    • Remove the 9 frame screws with a JIS #00 screwdriver.
    • The bottom three screws release the port cover at the bottom of the phone. The cover should lift off easily once the screws are out.
    • Pop the camera button frame off with a spudger. The home button should come off along with the frame.
    • Be gentle with the frame when removing it. The plastic is very thin and can easily break.
  4. LG K7 Rear Facing Camera Replacement: passo 4, immagine 1 di 2 LG K7 Rear Facing Camera Replacement: passo 4, immagine 2 di 2
    • Use a plastic opening tool to separate the screen from the outer frame.
    • Do not to bend the outer frame or the screen to when separating them. This can severely damage the phone.
  5. LG K7 Rear Facing Camera Replacement: passo 5, immagine 1 di 1
    • Insert the edge of a plastic opening tool underneath the camera connector that is attached to the camera by a flat, thin, and flexible sheet.
    • Slowly lever the connector free by pressing down on the opening tool's handle. The connector should be fairly solid and pop out by levering just one edge.
    • Be careful not to break or bend the connector or any part of the device you may be levering against.
Conclusione
James Ngo
Membro da: 01/19/18
461 Reputazione
4 Guide realizzate
Cal Poly, Team S21-G5, Banghart Winter 2018 Membro di Cal Poly, Team S21-G5, Banghart Winter 2018
CPSU-BANGHART-W18S21G5
4 Membri
8 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 399
