Salta al contenuto principale
LG K7 Charging Port Replacement
Cosa ti serve
  1. LG K7 Charging Port Replacement, Charging Port: passo 1, immagine 1 di 2 LG K7 Charging Port Replacement, Charging Port: passo 1, immagine 2 di 2
    • Remove the back cover by using the plastic opening tool.
    • Remove battery by using the plastic opening tool.
  2. LG K7 Charging Port Replacement: passo 2, immagine 1 di 1
    • Remove the nine 4mm Phillips #000 screws.
    • The cover should lift off easily once the screws are out.
    • Be gentle with the frame when removing it. The plastic is very thin and can easily break.
  3. LG K7 Charging Port Replacement: passo 3, immagine 1 di 1
    • Place the plastic opening tool between the screen and the plastic edge of the phone and pry carefully until screen pops off.
    • The frame is held to the rest of the phone with plastic tabs. Release each tab one at a time around the phone for the easiest removal.
    • Do not bend the outer frame or screen when separating them. This will severely damage the phone.
  4. LG K7 Charging Port Replacement: passo 4, immagine 1 di 1
    • Place the plastic opening tool between the blue motherboard and black plate and pry until the motherboard pops off.
  5. LG K7 Charging Port Replacement: passo 5, immagine 1 di 2 LG K7 Charging Port Replacement: passo 5, immagine 2 di 2
    • Heat up the four connection points using a soldering iron.
    • Once hot, gently push the port off.
    • Soldering iron is hot! Use with caution.
    • Be careful not to touch other components with the soldering iron.
Conclusione
Stephen Damm
Membro da: 11/07/19
167 Reputazione
1 Guida realizzata
IUPUI, Team S3-G2, Harley Fall 2019 Membro di IUPUI, Team S3-G2, Harley Fall 2019
IUPUI-HARLEY-F19S3G2
3 Membri
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 5
Tutti i Tempi: 556
