Salta al contenuto principale
LG K40 Disassembly
Cosa ti serve
  1. LG K40 Disassembly, Preparing for Disassembly: passo 1, immagine 1 di 2 LG K40 Disassembly, Preparing for Disassembly: passo 1, immagine 2 di 2
    • Prepare the LG K40 for Disassembly by placing the back against the Heatpad.
    • Heat the phone until it is hot to the touch.
  2. LG K40 Disassembly, Removing the Back: passo 2, immagine 1 di 2 LG K40 Disassembly, Removing the Back: passo 2, immagine 2 di 2
    • Once the phone is hot to the touch, place the phone screen facedown away from the heatpad.
    • Use your spudger, and carefully pry the back off of the Phone. Be extra careful to not damage the rear camera ribbon cable.
    • Once the back is free, place it next to the phone for continuing the disassembly.
  3. LG K40 Disassembly, Detaching the Rear Camera: passo 3, immagine 1 di 2 LG K40 Disassembly, Detaching the Rear Camera: passo 3, immagine 2 di 2
    • Using your spudger once more, carefully unplug the rear touch sensor ribbon cable, and set the back aside.
  4. LG K40 Disassembly, Unscrewing the Motherboard Cover: passo 4, immagine 1 di 1
    • Using your PH000 screw bit, remove the 15 screws on the internal motherboard casing. In the image, one of the 15 screws is shown.
  5. LG K40 Disassembly, Removing the Motherboard Covers: passo 5, immagine 1 di 3 LG K40 Disassembly, Removing the Motherboard Covers: passo 5, immagine 2 di 3 LG K40 Disassembly, Removing the Motherboard Covers: passo 5, immagine 3 di 3
    • To remove the top half of the cover, push in the plastic tabs around the casing. Then lift it off gently.
    • The remove the bottom half of the casing, push in the tabs and gently lift as well. Remember to be gentle to not damage the board underneath, as the bottom half is more difficult to remove.
  6. LG K40 Disassembly, Removing the battery: passo 6, immagine 1 di 1
    • To remove the battery, begin by unplugging the ribbon cable near the top of the battery.
    • Then, gently lift the battery with your spudger. In some cases, heat from the heat pad may help loosen the battery.
  7. LG K40 Disassembly, Removing the Motherboard: passo 7, immagine 1 di 1
    • To remove the Motherboard, begin by removing the SIM Card tray from the bottom right half of the casing. This will make removal much easier.
    • Next, lift the board gently away from its tabs that keep it in place.
    • Once lifted from all tabs, lift the board away from the phone case.
  8. LG K40 Disassembly, Removing the Vibrating Unit: passo 8, immagine 1 di 1
    • Gently lift the vibrating unit from the top left corner of the case.
  9. LG K40 Disassembly, All Done!: passo 9, immagine 1 di 1
    • Congratulations! You have just disassembled an LG K40!
Conclusione
Altre 5 persone hanno completato questa guida.
Jake Allen
Membro da: 04/06/22
676 Reputazione
4 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 32
Tutti i Tempi: 813
