Introduzione
Have you received a “Warning: Camera Failed” message or something similar? Is your camera lens on your LG K30 Phone cracked. These are signs that your LG Phone is in need a camera replacement.
Use this guide to install a new rear facing camera. As always, please ensure your phone is powered off completely.
Cosa ti serve
Power off your Phone before beginning disassembly.
Use the 'Jimmy' and 'Metal Spudger' to slowly pry open the outsides of the back case.
Use a spudger to carefully disconnect the front camera connector.
Use a spudger to disconnect the display cable connector.
Use a Spudger to flip the release tab on the rear-facing camera cable ZIF connector.
Remove the rear-facing camera.
