Introduzione
Are you having boot loop issues? This is when your LG K30 device does not start normally to reach the Home or Locked Screen and remains frozen at the device's logo, Recovery Mode or a lit up screen.
This guide will show you the necessary steps to replace your motherboard. Please ensure your phone is turned completely before replacing your motherboard.
Cosa ti serve
Power off your Phone before beginning disassembly.
Use the 'Jimmy' and 'Metal Spudger' to slowly pry open the outsides of the back case.
Use a spudger to carefully disconnect the front camera connector.
Use a spudger to disconnect the display cable connector.
Altre 4 persone hanno completato questa guida.
