Salta al contenuto principale
LG K30 Front-Facing Camera Replacement
Cosa ti serve
  1. LG K30 Front-Facing Camera Replacement, Battery: passo 1, immagine 1 di 2 LG K30 Front-Facing Camera Replacement, Battery: passo 1, immagine 2 di 2
    • Before disassembling your LG K30, discharge the battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your Phone before beginning disassembly.
    • Use the 'Jimmy' and 'Metal Spudger' to slowly pry open the outsides of the back case.
  2. LG K30 Front-Facing Camera Replacement: passo 2, immagine 1 di 1
    • Remove the thirteen 3.4 mm Phillips #00 screws securing the midframe to the display assembly.
  3. LG K30 Front-Facing Camera Replacement: passo 3, immagine 1 di 1
    • Use a metal spudger or plastic opening tool to pry open the outer cover.
  4. LG K30 Front-Facing Camera Replacement: passo 4, immagine 1 di 1
    • Use the flat end of a spudger to detach the battery connector from the logic board.
  5. LG K30 Front-Facing Camera Replacement: passo 5, immagine 1 di 2 LG K30 Front-Facing Camera Replacement: passo 5, immagine 2 di 2
    • Use a spudger to pry the battery from the phone.
    • There may be an adhesive on the back of the battery and the phone. Pry the battery gently to prevent puncture or damage.
    • Do not bend or puncture the battery.
  6. LG K30 Front-Facing Camera Replacement, Front-Facing Camera: passo 6, immagine 1 di 1
    • Use the plastic spudger to disconnect the cable connector.
  7. LG K30 Front-Facing Camera Replacement: passo 7, immagine 1 di 1
    • Gently pry out the front-facing camera from the device.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 246
