Salta al contenuto principale
LG K20 PLUS Front Camera Replacement
Cosa ti serve
  1. LG K20 PLUS Front Camera Replacement, Remove the back cover and battery: passo 1, immagine 1 di 2 LG K20 PLUS Front Camera Replacement, Remove the back cover and battery: passo 1, immagine 2 di 2
    • Remove the back cover by inserting a fingernail or opening pick here and disengaging the plastic clips.
    • Lift battery up here
  2. Attenzione: i passaggi 2-3 provengono da una guida contrassegnata come in corso.
    LG K20 PLUS Front Camera Replacement, Midframe: passo 2, immagine 1 di 1
    • Remove 11 Philips screws.
  3. LG K20 PLUS Front Camera Replacement: passo 3, immagine 1 di 2 LG K20 PLUS Front Camera Replacement: passo 3, immagine 2 di 2
    • Use fingernails or insert an opening pick into the gap between the digitizer and the midframe and pull the midframe outwards to disengage the plastic clips.
    • Carefully disengage the clips on the bottom as the headphone jack goes through the midframe.
    • Once all the clips have been disengaged, move the midframe outwards and downwards to disengage it from the headphone jack.
  4. LG K20 PLUS Front Camera Replacement, Front Camera: passo 4, immagine 1 di 1
    • Use an opening pick or a Halberd spudger to disconnect the front camera flex from its socket on the motherboard.
    • The front camera is held in by adhesive. Carefully pry between the camera and its bracket on the frame of the phone to remove it.
    • If you're having difficulty removing the front-facing camera, remove the motherboard to make more room.
Conclusione
Patrick
Membro da: 05/14/14
6.574 Reputazione
21 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 535
