Salta al contenuto principale
LG K10 Rear Camera Replacement
Cosa ti serve
Panoramica Video
  1. LG K10 Rear Camera Replacement, Rear Camera: passo 1, immagine 1 di 1
    • Power off the device
    • Remove the backing
  2. LG K10 Rear Camera Replacement: passo 2, immagine 1 di 1
    • Remove the battery
  3. LG K10 Rear Camera Replacement: passo 3, immagine 1 di 1
    • Unscrew every screw of the bottom of the phone and use guitar picks to remove the plastic frame of the phone
  4. LG K10 Rear Camera Replacement: passo 4, immagine 1 di 1
    • With a pick lift the side of the phone, in order to remove the backside
    • Repeat this step on all sides of the phone
  5. LG K10 Rear Camera Replacement: passo 5, immagine 1 di 1
    • Once the back is completely off, you now have complete access to the rear camera
    • You also now have access to the rear/ front speakers, and motherboard
  6. LG K10 Rear Camera Replacement: passo 6, immagine 1 di 1
    • Insert a plastic opening tool under the edge of the rear camera's press-fit connector. Lift the connector up and away from the motherboard to pop the ribbon cable free.
    • Remove the rear facing camera.
Conclusione
Altre 2 persone hanno completato questa guida.
Witrigs
Membro da: 11/24/15
69.647 Reputazione
378 Guide realizzate
Un commento
Can you upgrade the original camera with say a G5 camera?
Larry Smith - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 9
Tutti i Tempi: 1,641
