Salta al contenuto principale
LG Intuition Screen Protector Replacement
Cosa ti serve
  1. LG Intuition Screen Protector Replacement, Battery: passo 1, immagine 1 di 1
    • Turn the device so the two bottom screws are shown.
  2. LG Intuition Screen Protector Replacement: passo 2, immagine 1 di 1
    • Remove the two 7mm screws holding the back panel of the phone using the P5 bit and magnetic driver.
  3. LG Intuition Screen Protector Replacement: passo 3, immagine 1 di 1
    • Carefully use the plastic opening tool to pry the back panel of the phone from the front screen. This will expose the battery and other parts.
  4. LG Intuition Screen Protector Replacement: passo 4, immagine 1 di 1
    • Use the Phillips #0 screwdriver to remove the 5mm screw holding the metal bracket that protects the battery's ribbon cable.
  5. LG Intuition Screen Protector Replacement: passo 5, immagine 1 di 1
    • Carefully use the plastic opening tool to pry the ribbon cable connecting the battery to the motherboard of the phone.
  6. LG Intuition Screen Protector Replacement: passo 6, immagine 1 di 2 LG Intuition Screen Protector Replacement: passo 6, immagine 2 di 2
    • Gently raise the battery from its compartment.
  7. LG Intuition Screen Protector Replacement, Plastic Motherboard Shield: passo 7, immagine 1 di 1
    • Remove the thirteen 5mm screws holding the plastic shield covering the motherboard using the Phillips #00 screwdriver.
  8. LG Intuition Screen Protector Replacement: passo 8, immagine 1 di 1
    • Carefully use the plastic opening tool to pry the plastic shield from the motherboard. This will expose the motherboard and ribbon cables for each component.
  9. LG Intuition Screen Protector Replacement, Camera: passo 9, immagine 1 di 1
    • Carefully use the plastic opening tool to pry the ribbon cable below the camera itself from the motherboard.
  10. LG Intuition Screen Protector Replacement: passo 10, immagine 1 di 1
    • Using the ribbon beneath the camera lift it upwards and pull the camera out.
  11. LG Intuition Screen Protector Replacement, Volume Buttons: passo 11, immagine 1 di 2 LG Intuition Screen Protector Replacement, Volume Buttons: passo 11, immagine 2 di 2
    • Slowly pull the ribbon cable upward releasing the volume buttons from the phone.
  12. LG Intuition Screen Protector Replacement, Screen Protector: passo 12, immagine 1 di 2 LG Intuition Screen Protector Replacement, Screen Protector: passo 12, immagine 2 di 2
    • Carefully use the plastic opening tool to pry the ribbon cable below the volume buttons on the left side of the phone.
    • Carefully use the plastic opening tool to pry the ribbon cable to the left of the camera.
  13. LG Intuition Screen Protector Replacement: passo 13, immagine 1 di 2 LG Intuition Screen Protector Replacement: passo 13, immagine 2 di 2
    • Carefully use the plastic opening tool to pry the wire that connects to the bottom home and back display buttons.
    • Carefully use the plastic opening tool to pry the second wire on the right side of the battery that also connects to the bottom home and back display buttons.
  14. LG Intuition Screen Protector Replacement: passo 14, immagine 1 di 1
    • Carefully use the plastic opening tool to pry the motherboard from the front screen.
  15. LG Intuition Screen Protector Replacement: passo 15, immagine 1 di 2 LG Intuition Screen Protector Replacement: passo 15, immagine 2 di 2
    • Remove the 5mm Phillips #00 screw below the volume buttons holding the plastic shield onto the screen display.
    • Remove the 5mm Phillips #00 screw on the top right of the phone.
  16. LG Intuition Screen Protector Replacement: passo 16, immagine 1 di 1
    • Carefully pull the ribbon cable upward and away from the front screen display.
  17. LG Intuition Screen Protector Replacement: passo 17, immagine 1 di 1
    • Carefully use the plastic opening tool to pry the screen protector from the display and motherboard.
  18. LG Intuition Screen Protector Replacement: passo 18, immagine 1 di 2 LG Intuition Screen Protector Replacement: passo 18, immagine 2 di 2
    • Slowly separate the front screen from the screen protector. This will remove the screen protector from the phone.
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 8
Tutti i Tempi: 305
