Salta al contenuto principale
LG Incite Back Panel Replacement
Cosa ti serve
  1. LG Incite Back Panel Replacement, Battery: passo 1, immagine 1 di 1
    • Hold the phone camera-side up and locate the rear cover.
  2. LG Incite Back Panel Replacement: passo 2, immagine 1 di 1
    • Place a thumb below the camera, apply a little pressure, and slide the cover toward the bottom of the phone.
  3. LG Incite Back Panel Replacement: passo 3, immagine 1 di 1
    • Place the plastic opening tool in the small slot below and to the left of the battery.
    • Pry the battery upward to remove it.
  4. LG Incite Back Panel Replacement, Back Panel: passo 4, immagine 1 di 1
    • Using the #00 Philips screw driver, unscrew the four 4.5mm screws located around the battery compartment.
  5. LG Incite Back Panel Replacement: passo 5, immagine 1 di 1
    • Wedge the plastic opening tool between the screen and the body of the device, using care to avoid damaging internal components.
    • Gently move the tool around the perimeter of the screen to separate it from the body.
    • You should not completely separate the screen from the device in this step.
  6. LG Incite Back Panel Replacement: passo 6, immagine 1 di 1
    • Flip the device over so the battery compartment faces up.
    • Press the scroll wheel, located in the upper-left corner, into the device to avoid damage.
    • Gently insert the plastic opening tool into the seam between the frame and front cover to separate the back panel from the device.
    • The volume, lock, and camera buttons are loose, so be careful not to misplace them.
Conclusione
Cal Poly, Team 2-18, Maness Spring 2013 Membro di Cal Poly, Team 2-18, Maness Spring 2013
CPSU-MANESS-S13S2G18
4 Membri
11 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 21
Tutti i Tempi: 721
