Salta al contenuto principale
Introduzione
We disassembled the LG Gram 15" to see how the Surface/MacBook competitor stacks up.
  1. Reference shot with packaging.
    • Reference shot with packaging.
  2. Reference shots. Reference shots. Reference shots.
    • Reference shots.
  3. We first use tweezers to remove the three plastic screw covers and five rubber bumpers. We find eight Phillips screws holding the case together. After removing the screws, we use picks to remove the lower case which is held in with clips.
    • We first use tweezers to remove the three plastic screw covers and five rubber bumpers.
    • We find eight Phillips screws holding the case together.
    • After removing the screws, we use picks to remove the lower case which is held in with clips.
  4. Lower case is removed to view the internals.
    • Lower case is removed to view the internals.
  5. Kit di riparazione batterie iPhone
    Solo $29.99
    Buy Now
    Solo $29.99
    Buy Now
  6. Battery comes out easily—just 6 screws and a connector on the motherboard. SSD is standard and user-upgradable. RAM is also standard and user-upgradable.
    • Battery comes out easily—just 6 screws and a connector on the motherboard.
    • SSD is standard and user-upgradable.
    • RAM is also standard and user-upgradable.
    • At this time, it's cool to note that you can remove the display assembly, speakers, daughterboard, backup battery, motherboard, trackpad, and the fan.
    • Perhaps slightly more useful knowledge: The only component we cannot remove is the keyboard.
  7. We chose the fan + heatpipe combo. 7 screws and 1 plug Followed closely by the motherboard. No surprises. In total < 10 screws, exactly 6 connectors, and the wireless card. There were some alignment pins that required a tiny bit of finagling, but if you know they're there this will take you less than a minute.
    • We chose the fan + heatpipe combo. 7 screws and 1 plug
    • Followed closely by the motherboard. No surprises. In total < 10 screws, exactly 6 connectors, and the wireless card.
    • There were some alignment pins that required a tiny bit of finagling, but if you know they're there this will take you less than a minute.
    • Trackpad's next. It's held in with 4 screws and pops out the top of the lower case.
    Is the CPU easily removable from the motherboard or is it soldered? In other words, is the processory/chip user-upgradable? Thank you -
    ken maready - Replica
  8. I/O board, wireless card, speakers, and CMOS battery. The speakers were held in with adhesive to supplement a pair of screws, but it peeled off the case cleanly and we could reuse it when reassembling the unit.
    • I/O board, wireless card, speakers, and CMOS battery.
    • The speakers were held in with adhesive to supplement a pair of screws, but it peeled off the case cleanly and we could reuse it when reassembling the unit.
    INTEL® DUAL BAND WIRELESS-AC 7265 is M.2 1216 or M.2 2230?
    Miguel Gandara - Replica
  9. Keyboard is hidden beneath thin-film insulator taped in place. If you're performing a keyboard replacement, you'll need to buy replacement adhesive for this film. It's is held in place with 48 screws, which sounds bad, but is par for the course for a repairable laptop. Here, the lack of glue in a laptop this compact is practically a miracle. It's is held in place with 48 screws, which sounds bad, but is par for the course for a repairable laptop. Here, the lack of glue in a laptop this compact is practically a miracle.
    • Keyboard is hidden beneath thin-film insulator taped in place. If you're performing a keyboard replacement, you'll need to buy replacement adhesive for this film.
    • It's is held in place with 48 screws, which sounds bad, but is par for the course for a repairable laptop. Here, the lack of glue in a laptop this compact is practically a miracle.
  10. Four screws later, the display assembly is free from the lower case.
    • Four screws later, the display assembly is free from the lower case.
  11. The LG Gram 15&quot; earns a 9 out of 10 on our repairability scale (10 is the easiest to repair): Most components are immediately accessible after removing the lower case cover.
    • The LG Gram 15" earns a 9 out of 10 on our repairability scale (10 is the easiest to repair):
    • Most components are immediately accessible after removing the lower case cover.
    • RAM and SSD are user-replaceable and parts for upgrades are readily accessible.
    • Battery is also user-replaceable.
    • Only Phillips screws are used throughout the device.
    • Manufacturer does not provide user-accessible repair documentation.
Linea Traguardo
Altre 7 persone hanno completato questa guida.
Jeff Suovanen
Membro da: 06/08/2013
227.002 Reputazione
198 Guide realizzate
iFixit Membro di iFixit
Community
101 Membri
8.681 Guide realizzate
Half the ram is solderded to the main board. You cannot upgrade to faster ram because of this. If i had know this in advance i would not have bought this laptop. So 9/10 is a bit high.
Freek Compagne - Replica
It appears that the screen is still in the case in the pictures here. Hopefully that can safely be taken apart too as I just ordered a replacement screen. Seeing that this example left the screen in the case, I would agree that 9/10 repairability might be high…
Curtis O'Reilly - Replica
Hi, did you manage to replace the screen successfully?
Alan -
Bought OEM battery from encompass and replaced battery within 1.5 hours. Notice the phillips head is not the average size. I improvised that step and the tweezers step with a pocket knife (8Cr13moV). For the disconnection of the battery from the motherboard, notice that you must pull the plug out towards the direction of the battery. Breakdown pictures were helpful.
randomo - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 35
Ultimi 7 Giorni: 160
Ultimi 30 Giorni: 782
Tutti i Tempi: 15,435
