Salta al contenuto principale
LG GW910 Keyboard Replacement
Cosa ti serve
  1. LG GW910 Keyboard Replacement, Motherboard: passo 1, immagine 1 di 2 LG GW910 Keyboard Replacement, Motherboard: passo 1, immagine 2 di 2
    • Remove the back cover by firmly pressing the triangle and push upwards.
    • Lift the bottom section to remove the cover.
  2. LG GW910 Keyboard Replacement: passo 2, immagine 1 di 2 LG GW910 Keyboard Replacement: passo 2, immagine 2 di 2
    • Remove the battery by lifting from the bottom.
  3. LG GW910 Keyboard Replacement: passo 3, immagine 1 di 1
    • Remove six 3mm PH000 screws.
  4. LG GW910 Keyboard Replacement: passo 4, immagine 1 di 3 LG GW910 Keyboard Replacement: passo 4, immagine 2 di 3 LG GW910 Keyboard Replacement: passo 4, immagine 3 di 3
    • Peel off the sticker with the metal spudger.
    • Remove one 1mm PH000 screw.
  5. LG GW910 Keyboard Replacement: passo 5, immagine 1 di 1
    • Pry open all four sides of the back-frame gently, using the metal spudger.
    • The back-frame should come out easily.
    • Volume button and shutter button may fall out during the process.
  6. LG GW910 Keyboard Replacement: passo 6, immagine 1 di 1
    • Pry off the connector using the iFixit opening tool to remove the communication board.
  7. LG GW910 Keyboard Replacement: passo 7, immagine 1 di 3 LG GW910 Keyboard Replacement: passo 7, immagine 2 di 3 LG GW910 Keyboard Replacement: passo 7, immagine 3 di 3
    • Pry off the connectors using the iFixit opening tool.
    • Disconnect the antenna using the iFixit opening tool.
    • The motherboard should be able to be removed easily.
  8. LG GW910 Keyboard Replacement, Keyboard: passo 8, immagine 1 di 1
    • Remove six 1mm PH00 screws.
  9. LG GW910 Keyboard Replacement: passo 9, immagine 1 di 2 LG GW910 Keyboard Replacement: passo 9, immagine 2 di 2
    • Peel off the tape to expose the hidden screw.
    • Replacement tape might be needed.
  10. LG GW910 Keyboard Replacement: passo 10, immagine 1 di 2 LG GW910 Keyboard Replacement: passo 10, immagine 2 di 2
    • Pry off the board from the side using the metal spudger tool.
    • Disconnect the antenna.
  11. LG GW910 Keyboard Replacement: passo 11, immagine 1 di 1
    • Remove the keyboard assembly from the main frame.
    • The keyboard cover is loose.
    • Make sure to pull the small keyboard battery out with the whole assembly
Conclusione
Jonas Ke
Membro da: 11/06/18
492 Reputazione
3 Guide realizzate
IUPUI, Team S1-G6, Hovde Fall 2018 Membro di IUPUI, Team S1-G6, Hovde Fall 2018
IUPUI-HOVDE-F18S1G6
3 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 9
Tutti i Tempi: 113
