Salta al contenuto principale
LG G8 ThinQ Vibration Motor Replacement
Cosa ti serve
  1. LG G8 ThinQ Vibration Motor Replacement, SIM Card Tray: passo 1, immagine 1 di 3 LG G8 ThinQ Vibration Motor Replacement, SIM Card Tray: passo 1, immagine 2 di 3 LG G8 ThinQ Vibration Motor Replacement, SIM Card Tray: passo 1, immagine 3 di 3
    • Unplug and power off your phone before you begin.
    • Insert the SIM card eject tool into the pinhole in the lower right side of the phone.
    • Remove the SIM card and tray.
  2. LG G8 ThinQ Vibration Motor Replacement, Back Panel: passo 2, immagine 1 di 3 LG G8 ThinQ Vibration Motor Replacement, Back Panel: passo 2, immagine 2 di 3 LG G8 ThinQ Vibration Motor Replacement, Back Panel: passo 2, immagine 3 di 3
    • Place the phone so that the screen is facing down.
    • Insert opening cards between the back panel and frame of the phone to loosen the clips and adhesive.
    • Using equal pressure, carefully pry the back panel away from the phone.
    • Once enough space has been created, use an opening tool to completely separate the back panel from the phone.
  3. LG G8 ThinQ Vibration Motor Replacement, Midframe: passo 3, immagine 1 di 3 LG G8 ThinQ Vibration Motor Replacement, Midframe: passo 3, immagine 2 di 3 LG G8 ThinQ Vibration Motor Replacement, Midframe: passo 3, immagine 3 di 3
    • Remove all 14 screws from the midframe using a Phillips #000 screwdriver.
    • Work an opening tool around the perimeter of the midframe to pry and remove it from the phone.
  4. LG G8 ThinQ Vibration Motor Replacement, Speaker System: passo 4, immagine 1 di 3 LG G8 ThinQ Vibration Motor Replacement, Speaker System: passo 4, immagine 2 di 3 LG G8 ThinQ Vibration Motor Replacement, Speaker System: passo 4, immagine 3 di 3
    • Using an opening tool, carefully pry out remove the speaker system from the phone.
  5. LG G8 ThinQ Vibration Motor Replacement, Headphone Jack: passo 5, immagine 1 di 3 LG G8 ThinQ Vibration Motor Replacement, Headphone Jack: passo 5, immagine 2 di 3 LG G8 ThinQ Vibration Motor Replacement, Headphone Jack: passo 5, immagine 3 di 3
    • Using an opening tool, carefully disconnect the ribbon cable connecting the 3.5mm audio jack to the motherboard.
    • Remove the screw holding the 3.5 mm audio jack in place using a Phillips #000 screwdriver.
    • Remove the audio jack from the phone.
  6. LG G8 ThinQ Vibration Motor Replacement, Battery: passo 6, immagine 1 di 1
    • Flip phone so that screen is facing up.
    • Using a heating pad, hairdryer, or heat gun, apply heat to loosen the adhesive beneath the battery.
    • Be careful to not overheat the phone; the screen and battery are susceptible to damage.
    • The adhesive can be difficult to soften; it may take many attempts.
  7. LG G8 ThinQ Vibration Motor Replacement: passo 7, immagine 1 di 2 LG G8 ThinQ Vibration Motor Replacement: passo 7, immagine 2 di 2
    • Using an opening tool, carefully pry up the ribbon cable to disconnect the battery.
  8. LG G8 ThinQ Vibration Motor Replacement: passo 8, immagine 1 di 3 LG G8 ThinQ Vibration Motor Replacement: passo 8, immagine 2 di 3 LG G8 ThinQ Vibration Motor Replacement: passo 8, immagine 3 di 3
    • Using opening cards or an opening tool, carefully pry around the edges of the battery.
    • If you have trouble prying up the battery, the adhesive may not be loose enough. Re-apply heat, or use some isopropyl alcohol under the battery, allowing it to penetrate for several minutes to weaken the adhesive.
    • Remove the battery from the phone.
  9. LG G8 ThinQ Vibration Motor Replacement, Motherboard: passo 9, immagine 1 di 2 LG G8 ThinQ Vibration Motor Replacement, Motherboard: passo 9, immagine 2 di 2
    • Use an opening tool to disconnect the two coaxial cables from the motherboard.
  10. LG G8 ThinQ Vibration Motor Replacement: passo 10, immagine 1 di 3 LG G8 ThinQ Vibration Motor Replacement: passo 10, immagine 2 di 3 LG G8 ThinQ Vibration Motor Replacement: passo 10, immagine 3 di 3
    • Using an opening tool, carefully disconnect the screen ribbon cable from the motherboard.
    • Using an opening tool, carefully pry up the motherboard from the frame and remove it from the phone.
  11. LG G8 ThinQ Vibration Motor Replacement, Vibration Motor: passo 11, immagine 1 di 2 LG G8 ThinQ Vibration Motor Replacement, Vibration Motor: passo 11, immagine 2 di 2
    • Remove the vibration motor from the phone casing using an opening tool.
    • Heat the vibration motor from the other side of the phone to loosen adhesive if needed.
Conclusione
Kristen Gismondi
Membro da: 11/12/14
92.015 Reputazione
241 Guide realizzate
iFixit Membro di iFixit
Staff
118 Membri
19.450 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 432
