Introduzione
In this guide, you will be removing the rear camera sensor. Use this guide if you find the rear camera has trouble focusing.
Cosa ti serve
While holding the battery release button, pull the bottom end of the phone out of the body.
Once the screen has been separated from the back of the phone, now you can remove the motherboard.
Using the #00 Philips head, remove the six 2.7mm Phillips screws.
Make sure to transfer the earpiece from the old screen to the new screen or else you wouldn't be able to hear anyone when you make phone calls!
The component is fragile so don't try to force it to come out with a pair of tweezers. A pick should be able to wedge it out.
Be careful with the adhesive that's connected to it. It's easy to pull out.
Using the plastic opening tool, remove the ribbon attaching the sensor to the motherboard.
Altre 6 persone hanno completato questa guida.
Un commento
Is that the camera sensor that has been removed or the wide angle camera?
