Salta al contenuto principale
Introduzione
This guide will instruct you on how to replace a cracked or damaged LCD screen and digitizer assembly in your LG G4 smartphone.
It may be necessary to use a pre-cut LG G4 adhesive strip or Tesa 61395 tape to secure your new screen to your device.
  1. Make sure the phone is powered off.
    • Make sure the phone is powered off.
    • Remove the rear cover by placing the plastic opening tool in the groove on the bottom left side of the LG G4 and gently prying up.
  2. Place the plastic opening tool at the bottom edge of the battery and lift up. Carefully remove battery with your hands. Place the plastic opening tool at the bottom edge of the battery and lift up. Carefully remove battery with your hands.
    • Place the plastic opening tool at the bottom edge of the battery and lift up. Carefully remove battery with your hands.
  3. Remove the eleven 3.9 mm Phillips #00 screws found at the back of the phone. Remove the eleven 3.9 mm Phillips #00 screws found at the back of the phone. Remove the eleven 3.9 mm Phillips #00 screws found at the back of the phone.
    • Remove the eleven 3.9 mm Phillips #00 screws found at the back of the phone.
  4. Once all the screws have been removed, place the plastic opening tool in the lower left corner and firmly lift the cover up. Detach the cover with your fingers Detach the cover with your fingers
    • Once all the screws have been removed, place the plastic opening tool in the lower left corner and firmly lift the cover up.
    • Detach the cover with your fingers
  5. Remove the following four press-fit connectors with the flat edge of a plastic spudger or opening tool: Front-facing camera connector.
    • Remove the following four press-fit connectors with the flat edge of a plastic spudger or opening tool:
    • Front-facing camera connector.
    • Rear-facing camera connector.
    • Digitizer connector.
    • The rear-facing camera may be held down to the frame with two sided tape. Try to move the camera with the spudger prior to lifting the motherboard If it does not budge, use the same tool to pry it from the frame to avoid damaging the connector cable in the next step.
  6. Kit riparazione batterie MacBook
    A partire da $69.99
    Buy Now
    A partire da $69.99
    Buy Now
  7. Remove the motherboard by lifting it up using the plastic opening tool and your fingers . Remove the motherboard by lifting it up using the plastic opening tool and your fingers .
    • Remove the motherboard by lifting it up using the plastic opening tool and your fingers .
    • Use a heat gun over the auxiliary port to soften the adhesive that secures it to the plastic housing.
    • Insert a nylon spudger into the auxiliary port and gently pry upward to free the port.
    • Use a pair of tweezers to remove the adhesive strip that secures the digitizer ribbon cable.
  8. Insert the flat side of a nylon spudger below the digitizer ribbon cable to free it from the adhesive. You may use your fingers to pull the ribbon cable gently as you free the panel from the adhesive with the spudger. It may be necessary to apply more heat if the adhesive is still too strong.
    • Insert the flat side of a nylon spudger below the digitizer ribbon cable to free it from the adhesive.
    • You may use your fingers to pull the ribbon cable gently as you free the panel from the adhesive with the spudger. It may be necessary to apply more heat if the adhesive is still too strong.
  9. Use a heat gun or an iOpener to soften the adhesive underneath the edges of the screen. Use a heat gun or an iOpener to soften the adhesive underneath the edges of the screen.
    • Use a heat gun or an iOpener to soften the adhesive underneath the edges of the screen.
    • Use a heavy duty suction cup and firmly pull the screen away from the frame to create a small gap.
    • There is a very thin strip of adhesive that holds the screen to the frame; this step should not require excessive force. Apply additional heat along the edges of the phone if the screen is difficult to free.
    • Insert a plastic opening pick into the gap between the screen and the plastic housing.
    • Slide the plastic opening pick along the border of the screen to break any additional adhesive and free the screen assembly.
  10. Remove the LCD screen & digitizer assembly. Feed the digitizer ribbon cable gently through the frame. Feed the digitizer ribbon cable gently through the frame.
Conclusione
Altre 18 persone hanno completato questa guida.
Richard Suovanen
Membro da: 07/02/2017
15.046 Reputazione
10 Guide realizzate
iFixit Membro di iFixit
Community
98 Membri
8.963 Guide realizzate
It is possible replace the digitalizer only? Thanks
Nene indy - Replica
Per the LG G4 Teardown guide, the glass, digitizer, and LCD are all fused together, so you have to replace the whole assembly
Eric Clothier - Replica
Lorsqu’on remplace l’ensemble écran + LCD achetés ensemble et que l’on transfère les pièces de l’ancien cadre (caméra, vibreur…), il ne faut pas oublier de transférer également 3 petits caoutchoucs carrés noir ou gris (2 en haut de chaque coté du haut parleur, et 1 en bas à gauche de la prise jack), sinon le détecteur de proximité ne marche pas et l’écran s’éteint et le reste lorsqu’on téléphone…
Nevile - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 17
Ultimi 7 Giorni: 76
Ultimi 30 Giorni: 302
Tutti i Tempi: 17,664
