Salta al contenuto principale
LG G3 Vigor Earpiece Speaker Replacement
Cosa ti serve
  1. LG G3 Vigor Earpiece Speaker Replacement, Rear Case: passo 1, immagine 1 di 1
    • Locate the notch on the bottom right of the phone.
  2. LG G3 Vigor Earpiece Speaker Replacement: passo 2, immagine 1 di 1
    • Gently pull the cover on the back of the phone off to locate the battery.
  3. LG G3 Vigor Earpiece Speaker Replacement, Battery: passo 3, immagine 1 di 1
    • Remove the battery by lifting from the slot at the bottom of the battery.
  4. LG G3 Vigor Earpiece Speaker Replacement, Midframe: passo 4, immagine 1 di 1
    • Remove the twelve Phillips #00 screws securing the midframe to the rest of the phone.
  5. LG G3 Vigor Earpiece Speaker Replacement: passo 5, immagine 1 di 3 LG G3 Vigor Earpiece Speaker Replacement: passo 5, immagine 2 di 3 LG G3 Vigor Earpiece Speaker Replacement: passo 5, immagine 3 di 3
    • Work a plastic opening tool around the perimeter of the phone to separate the midframe from the rest of the phone.
  6. LG G3 Vigor Earpiece Speaker Replacement, Rear Facing Camera: passo 6, immagine 1 di 1
    • Use the spudger to gently unplug the ribbon cable connected to the motherboard. Then remove the rear facing camera.
  7. LG G3 Vigor Earpiece Speaker Replacement, Front Facing Camera: passo 7, immagine 1 di 2 LG G3 Vigor Earpiece Speaker Replacement, Front Facing Camera: passo 7, immagine 2 di 2
    • Remove the front camera.
  8. LG G3 Vigor Earpiece Speaker Replacement, Motherboard: passo 8, immagine 1 di 1
    • Use the flat edge of a spudger to disconnect the motherboard ribbon connector.
  9. LG G3 Vigor Earpiece Speaker Replacement: passo 9, immagine 1 di 2 LG G3 Vigor Earpiece Speaker Replacement: passo 9, immagine 2 di 2
    • Use the pointed end of a spudger to push back the two motherboard retaining flaps.
    • The motherboard should now be able to be lifted out of the device.
  10. LG G3 Vigor Earpiece Speaker Replacement, Earpiece Speaker: passo 10, immagine 1 di 1
    • Remove the earpiece speaker with the metal spudger by prying it out.
Conclusione
Geoff Wacker
Membro da: 09/30/13
91.140 Reputazione
89 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 288
