Salta al contenuto principale
LG G3 Motherboard Replacement
Cosa ti serve
  1. LG G3 Motherboard Replacement, Back Cover: passo 1, immagine 1 di 2 LG G3 Motherboard Replacement, Back Cover: passo 1, immagine 2 di 2
    • Power off your phone before beginning disassembly.
    • Insert a thumbnail, or a prying tool like a spudger, into the notch at the bottom left of the back cover.
    • Pry the back cover up to separate its plastic clips.
  2. LG G3 Motherboard Replacement: passo 2, immagine 1 di 2 LG G3 Motherboard Replacement: passo 2, immagine 2 di 2
    • Lift the back cover to release the rest of the plastic clips and remove it.
    • In case you can't lift the back cover completely, slide your fingernail or your prying tool around the midframe to release the remaining clips.
    • To reinstall the back cover, press it firmly into place until you hear a snap from the plastic clips to form a seamless connection with the rear side of the phone.
  3. LG G3 Motherboard Replacement, Battery: passo 3, immagine 1 di 2 LG G3 Motherboard Replacement, Battery: passo 3, immagine 2 di 2
    • Use a fingernail or a prying tool at the marked notch to lever the battery out of its recess.
  4. LG G3 Motherboard Replacement: passo 4, immagine 1 di 2 LG G3 Motherboard Replacement: passo 4, immagine 2 di 2
    • Lift the battery out of its recess and remove it.
  5. LG G3 Motherboard Replacement, Loudspeaker: passo 5, immagine 1 di 1
    • Remove the four Phillips #00 screws (4 mm length).
  6. LG G3 Motherboard Replacement: passo 6, immagine 1 di 2 LG G3 Motherboard Replacement: passo 6, immagine 2 di 2
    • Insert a thumbnail, or a prying tool like a spudger, into the notch at the bottom left of the back cover you used earlier to remove the back cover.
    • Pry up the plastic panel, including the loudspeaker, until you can get a good grip.
  7. LG G3 Motherboard Replacement: passo 7, immagine 1 di 3 LG G3 Motherboard Replacement: passo 7, immagine 2 di 3 LG G3 Motherboard Replacement: passo 7, immagine 3 di 3
    • Carefully remove the plastic panel including the loudspeaker by gently pulling it away from the phone assembly.
  8. LG G3 Motherboard Replacement, Motherboard Cover Assembly: passo 8, immagine 1 di 1
    • Remove the eight Phillips #00 screws (4 mm length).
  9. LG G3 Motherboard Replacement: passo 9, immagine 1 di 3 LG G3 Motherboard Replacement: passo 9, immagine 2 di 3 LG G3 Motherboard Replacement: passo 9, immagine 3 di 3
    • Insert an opening pick between the bottom right corner of the motherboard cover and the motherboard.
    • Pry up the motherboard cover to open the plastic clips which hold the cover in its place.
    • The clips can be a bit resistive. If you're having trouble prying up the motherboard cover, slightly rotate the opening pick sideways to make the process easier.
    • Work your way along the right edge.
  10. LG G3 Motherboard Replacement: passo 10, immagine 1 di 3 LG G3 Motherboard Replacement: passo 10, immagine 2 di 3 LG G3 Motherboard Replacement: passo 10, immagine 3 di 3
    • Carefully lift the right edge of the motherboard cover.
    • The remaining plastic clips should open during this process or can be unhinged easily by hand.
    • Remove the motherboard assembly.
  11. LG G3 Motherboard Replacement, Motherboard: passo 11, immagine 1 di 2 LG G3 Motherboard Replacement, Motherboard: passo 11, immagine 2 di 2
    • Use a spudger to pry up and disconnect the display flex cable.
  12. LG G3 Motherboard Replacement: passo 12, immagine 1 di 2 LG G3 Motherboard Replacement: passo 12, immagine 2 di 2
    • Use a spudger to pry up and disconnect the digitizer flex cable.
  13. LG G3 Motherboard Replacement: passo 13, immagine 1 di 2 LG G3 Motherboard Replacement: passo 13, immagine 2 di 2
    • Use a spudger to pry up and disconnect the rear camera flex cable.
  14. LG G3 Motherboard Replacement: passo 14, immagine 1 di 2 LG G3 Motherboard Replacement: passo 14, immagine 2 di 2
    • Use a spudger to pry up and disconnect the front camera flex cable.
  15. LG G3 Motherboard Replacement: passo 15, immagine 1 di 2 LG G3 Motherboard Replacement: passo 15, immagine 2 di 2
    • During these next few steps, make sure to avoid damaging the flex cables you disconnected.
    • Slide an opening pick under the bottom right corner of the motherboard and slowly pry it out of its recess by rotating the opening pick sideways.
  16. LG G3 Motherboard Replacement: passo 16, immagine 1 di 2 LG G3 Motherboard Replacement: passo 16, immagine 2 di 2
    • Slide the opening pick under the right edge of the motherboard where the SIM card slot is located and pry it up by rotating the opening pick sideways.
  17. LG G3 Motherboard Replacement: passo 17, immagine 1 di 2 LG G3 Motherboard Replacement: passo 17, immagine 2 di 2
    • Grab the top section of the motherboard and carefully lift it out of the phone.
Conclusione
If possible, turn on your device and test your repair before installing new adhesive and resealing.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers Community for help.
Altre 4 persone hanno completato questa guida.
iFixit Membro di iFixit
Staff
135 Membri
16.732 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 32
Tutti i Tempi: 3,132
