Salta al contenuto principale
LG G Watch Spring Bar Pin Replacement
Cosa ti serve
  1. LG G Watch Spring Bar Pin Replacement, Wristband: passo 1, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    • Spring bars attach the two halves of the wristband to the watch body. The spring bar has a shoulder on either end.
    • Be prepared to apply some pressure with your fingers to perform the following action.
    • First, slide the wristband down on the spring bar to expose the shoulder of the spring bar.
    • Grasp the exposed shoulder with the tweezers to perform the next step.
  2. LG G Watch Spring Bar Pin Replacement: passo 2, immagine 1 di 2 LG G Watch Spring Bar Pin Replacement: passo 2, immagine 2 di 2
    • This is a challenging step. Do it carefully to prevent the spring bar from flying out of the wristband.
    • Use the tweezer to depress the spring bar so that it collapses by a few millimeters and pops out of the hole that was holding it in place.
    • Now carefully pull the other end of the spring bar to detach the wristband from the watch face.
    • Repeat steps 1 and 2 for the other wristband.
  3. LG G Watch Spring Bar Pin Replacement, Spring Bar Pin: passo 3, immagine 1 di 1
    • Slide the spring bar pin out of the wristband.
    • Repeat this step for the other wristband.
Conclusione
Geoff Wacker
Membro da: 09/30/13
92.047 Reputazione
89 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 18
Tutti i Tempi: 1,139
