Introduzione
This guide will show you how to remove the battery housing for the LG G Watch R.
Cosa ti serve
Place the watch upside down on a hard surface so that its back case is facing upright.
Use a T4 Torx Star screwdriver to remove the four 4.0 mm Torx screws from the corners of the back case.
With a plastic opening tool, disconnect the four connectors on the top of the motherboard.
Remove three 3.0 mm Phillips screws on the edges of the motherboard with a Phillips #000 screwdriver.
Add colored markup to indicate location of the 3 screws.
Use a plastic opening tool to pry the battery out of the device.
Thanks this was very helpful.
Thanks for your instructions
Thank you for this guide!
Pry the battery housing from the top right corner using a spudger.
Once loosened, remove the battery housing.
Altre 2 persone hanno completato questa guida.
Un commento
Hi there, do you know where can i buy the battery housing? Thank you..
So i bought a torx t5…but it is tooo big. It must br torx t4
Jetze Kooistra - Replica
I think I have damaged one of the screw heads while trying to unscrew the back of the watch.
I used the Torx T4… but the screw was covered in quite a bit of rust. Now the Torx T4 can’t get a grip.
What should I do? (Can anything be done?)
John Maher - Replica
Yea take a tiny file or a tiny Dremel attachment and carve a flat head groove in the head just enough so where you can use a flat head to get it
Andrew L rambeaut -
Thank you for good instructions! Saved me for 300€ (don’t have to buy a new wacth) ?
Ernst Kranke - Replica
