Cosa ti serve
First, slide the wristband down on the spring bar to expose the shoulder of the spring bar.
Grasp the exposed shoulder with the tweezers to perform the next step.
Use the T5 Torx screwdriver to unscrew the four silver 2mm x 3mm T5 screws that hold the back cover in place.
Use a pair of tweezers to remove the gasket that lies embedded in a groove that runs around the perimeter of the front half.
Use the spudger to gently lift up and disconnect the display connector.
Now use the spudger to disconnect the digitizer connector.
Apply a small amount of pressure to the back of the LCD to create a gap for the opening pick.
Gently work the pick around the perimeter of the device to loosen up the adhesive.
Altre 3 persone hanno completato questa guida.
4 Commenti
Where can you purchase replacement parts?
Someone knows where to find a screen replacement?, i found at alibaba but i have to buy 1k ... :(
I found a 00 screwdriver was better than 000 for removing the motherboard.
Be smart buy a used one for nuthin on eBay….
