Introduzione
This guide will walk you through with replacing the motherboard of you LG G Vista. You will need tweezers, a Phillips screwdriver #000, and a small plastic spudger, or your thumb nail.
Strumenti
Nessun attrezzo richiesto.
Parti
Nessuna parte richiesta.
  1. Make sure the device is powered off.
    • Make sure the device is powered off.
  2. Remove the back cover by gently prying open the case of the device from the charging port.
    • Remove the back cover by gently prying open the case of the device from the charging port.
    • Lift the battery out of its place by prying up from the small notch at the base of the battery.
    • Remove the eight 3.0 mm screws using the Phillips #000 screwdriver.
    • Remove the hard shell covering the motherboard.
    • Use a pair of tweezers to lift up the white antenna wire. On the other side of the logic board, do the same for the black antenna wire.
    • Use the tweezers to remove the four connectors as well as the back camera.
    • Be careful not to directly touch the camera lenses.
    • Lift up and remove the motherboard from the device.
Conclusione
Altre 2 persone hanno completato questa guida.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 11
Tutti i Tempi: 170
