Salta al contenuto principale
LG G Vista Battery Replacement
  1. LG G Vista Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Make sure the device is powered off.
  2. LG G Vista Battery Replacement: passo 2, immagine 1 di 1
    • Remove the back cover by gently prying open the case of the device from the charging port.
  3. LG G Vista Battery Replacement: passo 3, immagine 1 di 1
    • Lift the battery out of its place by prying up from the small notch at the base of the battery.
Conclusione
Make sure battery is perfectly fitted into it's spot before replacing the back cover. Power phone on to ensure the new battery is working properly.
Altre 2 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 5
Tutti i Tempi: 673
