Introduzione
If you are hearing static or any distortion through your headphones then you might need to replace your headphone port. This guide will start with taking the back cover off and end with replacing your headphone port.
Cosa ti serve
Remove the back cover by placing the plastic opening tool on the bottom left side of the device and gently prying up.
Carefully use the Phillips #00 screwdriver to remove the eleven 3.9mm visible screws found on the back. The screws to be removed are marked with the given indicators.
When you have finished removing all of the screws, place the plastic opening tool in the groove at the bottom left corner of the motherboard cover and lift up.
Make sure to remove the SIM card before you remove the motherboard cover. You can get the cover off without doing this, but the SIM card will be stuck underneath the cover once you put it back together.
Once a clip is released, you can detach the motherboard cover with your fingers and set aside.
Place the plastic opening tool under the headphone jack in the bottom corner and lift up. Remove the headphone port with your fingers after you have pried it loose.
Altre 3 persone hanno completato questa guida.
2 Commenti
What kind of adhesive to you use to replace jack?
