Introduzione
If you aren't able to take pictures or if the quality of the images on your tablet are poor, it may be time to replace the camera. This guide will properly show you how to replace the rear-facing camera on the LG G Pad X 8.3.
Ricambi
Nessuna parte specificata.
Remove the cover of the SD card. Find it on the right side of the back of the tablet.
Press the SD card in to make it pop out.
With a Phillips #000 screwdriver, unscrew the one 4.0 mm screw that is holding down the speaker.
Use the magnetic mat to keep track of the tiny screw(s).
With the Phillips #000 screwdriver, unscrew the four 4.0 mm screw that are holding down the motherboard.
Insert the plastic opening tool under the ribbon connector that is holding the rear-facing camera down and lift it up.
