Introduzione
The motherboard is the foundation of any electronic device. This guide will walk you through the replacement of one of the most essential components of the LG G Pad X 8.3.
Strumenti
Parti
Nessuna parte specificata.
Remove the cover of the SD card. Find it on the right side of the back of the tablet.
Press the SD card in to make it pop out.
With a Phillips #000 screwdriver, unscrew the one 4.0 mm screw that is holding down the speaker.
Use the magnetic mat to keep track of the tiny screw(s).
With the Phillips #000 screwdriver, unscrew the four 4.0 mm screw that are holding down the motherboard.
Use a plastic opening tool to lift up the ribbon connector at the bottom of the motherboard.
The end of this flex is a small connector that is hidden under a piece of adhesive. Carefully pull this up or the end will tear off.
Lift and release the remaining ribbon connectors in the upper left corner of the motherboard with a plastic opening tool.
