Introduzione
The motherboard is the foundation of any electronic device. This guide will walk you through the replacement of one of the most essential components of the LG G Pad X 8.3.
Ricambi
Nessuna parte specificata.
Remove the cover of the SD card. Find it on the right side of the back of the tablet.
Press the SD card in to make it pop out.
With a Phillips #000 screwdriver, unscrew the one 4.0 mm screw that is holding down the speaker.
Use the magnetic mat to keep track of the tiny screw(s).
With the Phillips #000 screwdriver, unscrew the four 4.0 mm screw that are holding down the motherboard.
