Introduzione
This guide will take you through the very easy process of replacing the downward facing speaker that has either died or blown out.
Cosa ti serve
Power off the device before starting speaker replacement.
Remove SD card and SIM Card.
With the opening tool, gently pry the back plate away from the main board. The corners are the easiest spots to start at.
Gently pull the back cover away from the adhesive on the battery.
