Salta al contenuto principale
LG G Pad X 8.0 Motherboard Replacement
Cosa ti serve
  1. LG G Pad X 8.0 Motherboard Replacement, Removing Backplate: passo 1, immagine 1 di 1
    • Power off the device before starting battery replacement.
    • Remove SD card and SIM Card.
    • With the opening tool, gently pry the back plate away from the main board. The corners are the easiest spots to start at.
  2. LG G Pad X 8.0 Motherboard Replacement, Peeling Back Cover Off: passo 2, immagine 1 di 2 LG G Pad X 8.0 Motherboard Replacement, Peeling Back Cover Off: passo 2, immagine 2 di 2
    • Gently pull the back cover away from the adhesive on the battery.
    • It may be possible to use a blow dryer on low heat but I'd advise against it unless absolutely necessary.
  3. LG G Pad X 8.0 Motherboard Replacement, Detaching Old Battery: passo 3, immagine 1 di 3 LG G Pad X 8.0 Motherboard Replacement, Detaching Old Battery: passo 3, immagine 2 di 3 LG G Pad X 8.0 Motherboard Replacement, Detaching Old Battery: passo 3, immagine 3 di 3
    • Slowly and gently lift the power cable upwards.
    • Unscrew the 4 screws keeping the battery in place, set aside.
  4. LG G Pad X 8.0 Motherboard Replacement, Removing the Battery: passo 4, immagine 1 di 1
    • Remove the battery by pulling up gently.
  5. LG G Pad X 8.0 Motherboard Replacement, Disconnect Cables: passo 5, immagine 1 di 3 LG G Pad X 8.0 Motherboard Replacement, Disconnect Cables: passo 5, immagine 2 di 3 LG G Pad X 8.0 Motherboard Replacement, Disconnect Cables: passo 5, immagine 3 di 3
    • Pry the connector for the camera up.
    • Pry the connector for the USB module up.
    • Pry the cable connecting the metal circle.
  6. LG G Pad X 8.0 Motherboard Replacement, Remove screws: passo 6, immagine 1 di 3 LG G Pad X 8.0 Motherboard Replacement, Remove screws: passo 6, immagine 2 di 3 LG G Pad X 8.0 Motherboard Replacement, Remove screws: passo 6, immagine 3 di 3
    • Unscrew the 3 screws holding the USB module down.
    • Unscrew the 2 screws keeping the motherboard in place.
    • Finally, the two screws for the micro USB port.
  7. LG G Pad X 8.0 Motherboard Replacement: passo 7, immagine 1 di 1
    • Gently lift up the display connector.
    • Be careful, too much pressure can cause the digitizer/screen to crack as it is right below the metal.
  8. LG G Pad X 8.0 Motherboard Replacement, Removing the Motherboard: passo 8, immagine 1 di 1
    • Remove the motherboard by pulling it straight up and away from the tablet body.
Conclusione
Altre 4 persone hanno completato questa guida.
[deleted]
Membro da: 05/18/17
1.146 Reputazione
3 Guide realizzate
2 Commenti
Would my motherboard to my pad be no good due to water damage it’s been 3 months still won’t turn on. The little sticker is pink still but my battery smells burnt. Could I take out the mother and use some air dust ?
Joe - Replica
You may need to replace the battery as it sounds like it shorted out. A burnt smell more than likely means the battery is damaged.
Have you tried replacing the battery yet?
[deleted] -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 1,826
