Introduzione
The motherboard replacement is more time extensive than a simple battery swap but should still be manageable for any novice. Keep track of your screws since they are tiny and easy to lose.
Cosa ti serve
Power off the device before starting battery replacement.
Remove SD card and SIM Card.
With the opening tool, gently pry the back plate away from the main board. The corners are the easiest spots to start at.
Gently pull the back cover away from the adhesive on the battery.
Slowly and gently lift the power cable upwards.
Unscrew the 4 screws keeping the battery in place, set aside.
Pry the connector for the camera up.
Pry the connector for the USB module up.
Pry the cable connecting the metal circle.
Unscrew the 3 screws holding the USB module down.
Unscrew the 2 screws keeping the motherboard in place.
Finally, the two screws for the micro USB port.
Remove the motherboard by pulling it straight up and away from the tablet body.
Altre 4 persone hanno completato questa guida.
2 Commenti
Would my motherboard to my pad be no good due to water damage it’s been 3 months still won’t turn on. The little sticker is pink still but my battery smells burnt. Could I take out the mother and use some air dust ?
You may need to replace the battery as it sounds like it shorted out. A burnt smell more than likely means the battery is damaged.
Have you tried replacing the battery yet?
