Salta al contenuto principale
LG G Pad X 8.0 Battery Replacement
Cosa ti serve
  1. LG G Pad X 8.0 Battery Replacement, Removing Backplate: passo 1, immagine 1 di 1
    • Power off the device before starting battery replacement.
    • Remove SD card and SIM Card.
    • With the opening tool, gently pry the back plate away from the main board. The corners are the easiest spots to start at.
  2. LG G Pad X 8.0 Battery Replacement, Peeling Back Cover Off: passo 2, immagine 1 di 2 LG G Pad X 8.0 Battery Replacement, Peeling Back Cover Off: passo 2, immagine 2 di 2
    • Gently pull the back cover away from the adhesive on the battery.
    • It may be possible to use a blow dryer on low heat but I'd advise against it unless absolutely necessary.
  3. LG G Pad X 8.0 Battery Replacement, Detaching Old Battery: passo 3, immagine 1 di 3 LG G Pad X 8.0 Battery Replacement, Detaching Old Battery: passo 3, immagine 2 di 3 LG G Pad X 8.0 Battery Replacement, Detaching Old Battery: passo 3, immagine 3 di 3
    • Slowly and gently lift the power cable upwards.
    • Unscrew the 4 screws keeping the battery in place, set aside.
  4. LG G Pad X 8.0 Battery Replacement, Removing the Battery: passo 4, immagine 1 di 1
    • Remove the battery by pulling up gently.
Conclusione
Altre 17 persone hanno completato questa guida.
[deleted]
Membro da: 05/18/17
1.146 Reputazione
3 Guide realizzate
10 Commenti
Thank you perfect
Robert Begliutti - Replica
I was going to do this to fix my son's tablet and then I looked up the cost of a replacement battery on eBay. Almost $100! Do you have a good source for a new battery?
poeticpyr07 - Replica
Unfortunately, no, there does not seem to be a good part supplier for the G Pad X 8.0. As you mention, the best I see is eBay at $82.
[deleted] -
2 years on they're $14
Carlos Mendonca -
I have researched this battery, the LG BL T-20. I found one that is 4800 MaH. The LG Gpad X8.0 has the same battery that is 4650 MaH. If I order the 4800 MaH, will it work?
luvgod10 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 16
Ultimi 30 Giorni: 41
Tutti i Tempi: 14,957
