Salta al contenuto principale
LG G Pad F 7.0 Battery Replacement
Cosa ti serve
  1. LG G Pad F 7.0 Battery Replacement, Battery: passo 1, immagine 1 di 2 LG G Pad F 7.0 Battery Replacement, Battery: passo 1, immagine 2 di 2
    • Open up the SIM port, on the top right corner (screen face down).
    • Press the SIM card (white plastic) to pop it out.
    • Remove SIM card and set aside.
  2. LG G Pad F 7.0 Battery Replacement: passo 2, immagine 1 di 2 LG G Pad F 7.0 Battery Replacement: passo 2, immagine 2 di 2
    • Use the plastic opening tool to pry the plastic backing off of the internal block. Start at the location with the SIM port to avoid damage to internal components.
    • Do this by finding the seam between the edge of the screen and the plastic backing, and prying between the two.
    • Work your way all the way around the edge of the screen, and remove the plastic backing when it is loose.
  3. LG G Pad F 7.0 Battery Replacement: passo 3, immagine 1 di 1
    • Locate the large orange ribbon cable, pry off the side shown in the image.
  4. LG G Pad F 7.0 Battery Replacement: passo 4, immagine 1 di 2 LG G Pad F 7.0 Battery Replacement: passo 4, immagine 2 di 2
    • Use the plastic opening tool to pry the multicolor wire cables off, applying force up away from the tablet.
    • Use the plastic opening tool to pry up the battery. There is adhesive underneath the battery, so use a small amount of force. Work your way around the edge of the battery to pry it off.
Conclusione
Matt Kloos
Membro da: 01/25/17
249 Reputazione
2 Guide realizzate
Cal Poly, Team 8-5, Banghart Winter 2017 Membro di Cal Poly, Team 8-5, Banghart Winter 2017
CPSU-BANGHART-W17S8G5
3 Membri
10 Guide realizzate
Un commento
Pictures are all in focus and easy to follow
Jonah Basl - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 6
Tutti i Tempi: 680
