Salta al contenuto principale
Introduzione
If your volume control buttons are not working properly, it may be time to replace them. This guide will show you how to replace the volume control buttons.
  1. With the tablet face down, pull the SD card slot cover out. Using a Phillips #000 screwdriver, remove the 3mm screw located in the SD card slot.
    • With the tablet face down, pull the SD card slot cover out.
    • Using a Phillips #000 screwdriver, remove the 3mm screw located in the SD card slot.
  2. Insert a plastic opening tool in the small crevasse between the screen and the back panel. Pry the screen away from the back panel. Repeat this on each edge of the device.
    • Insert a plastic opening tool in the small crevasse between the screen and the back panel.
    • Pry the screen away from the back panel.
    • Repeat this on each edge of the device.
    • We found it helpful to leave multiple plastic opening tools wedged in the crevasse to prevent it from closing.
    • This requires heavy force. The back of the device is attached with an adhesive. If the back panel is too hard to remove, use the iOpener.
  3. After using the plastic opening tools, pry the device open with your hands. Remove the back panel from the screen.
    • After using the plastic opening tools, pry the device open with your hands.
    • Remove the back panel from the screen.
  4. With the screen facing towards you and the top of the tablet towards your left, locate the volume buttons on the left side. Using a spudger or your hands, remove the volume control buttons, which are attached with adhesive.
    • With the screen facing towards you and the top of the tablet towards your left, locate the volume buttons on the left side.
    • Using a spudger or your hands, remove the volume control buttons, which are attached with adhesive.
Conclusione
Mario Salguero
Membro da: 14/09/2015
781 Reputazione
6 Guide realizzate
CSU Fullerton, Team 1-6, Bruce Fall 2015 Membro di CSU Fullerton, Team 1-6, Bruce Fall 2015
CSUF-BRUCE-F15S1G6
4 Membri
14 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 6
Tutti i Tempi: 893
