Salta al contenuto principale
LG G Pad 8.3 Speaker Replacement
Cosa ti serve
  1. LG G Pad 8.3 Speaker Replacement, Back Panel: passo 1, immagine 1 di 2 LG G Pad 8.3 Speaker Replacement, Back Panel: passo 1, immagine 2 di 2
    • With the tablet face down, pull the SD card slot cover out.
    • Using a Phillips #000 screwdriver, remove the 3mm screw located in the SD card slot.
  2. LG G Pad 8.3 Speaker Replacement: passo 2, immagine 1 di 3 LG G Pad 8.3 Speaker Replacement: passo 2, immagine 2 di 3 LG G Pad 8.3 Speaker Replacement: passo 2, immagine 3 di 3
    • Insert a plastic opening tool in the small crevasse between the screen and the back panel.
    • Pry the screen away from the back panel.
    • Repeat this on each edge of the device.
    • We found it helpful to leave multiple plastic opening tools wedged in the crevasse to prevent it from closing.
    • This requires heavy force. The back of the device is attached with an adhesive. If the back panel is too hard to remove, use the iOpener.
  3. LG G Pad 8.3 Speaker Replacement: passo 3, immagine 1 di 2 LG G Pad 8.3 Speaker Replacement: passo 3, immagine 2 di 2
    • After using the plastic opening tools, pry the device open with your hands.
    • Remove the back panel from the screen.
    • Remove the four 3 mm Phillips #000 screws that are attached to the speaker.
    • These screws are very small so make sure to keep track of them. You can use iFixit's Pro Magnetic Project Mat to help.
  4. LG G Pad 8.3 Speaker Replacement: passo 5, immagine 1 di 1
    • Use your fingers to remove the speaker.
Conclusione
Altre 4 persone hanno completato questa guida.
CSU Fullerton, Team 1-6, Bruce Fall 2015 Membro di CSU Fullerton, Team 1-6, Bruce Fall 2015
CSUF-BRUCE-F15S1G6
4 Membri
14 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 5
Tutti i Tempi: 1,573
