Introduzione
If your tablet isn't working properly, you may need to replace the motherboard. This guide will show you how to replace the motherboard.
Cosa ti serve
With the tablet face down, pull the SD card slot cover out.
Using a Phillips #000 screwdriver, remove the 3mm screw located in the SD card slot.
Attrezzo utilizzato in questo passaggio:Magnetic Project Mat$19.95
Remove the four 3 mm Phillips #000 screws that are attached to the speaker.
Altre 8 persone hanno completato questa guida.
