Salta al contenuto principale
LG G Pad 8.3 4G Back Panel Replacement
Cosa ti serve
  1. LG G Pad 8.3 4G Back Panel Replacement, Back Panel: passo 1, immagine 1 di 1
    • With the screen faced up, insert the metal spudger into the crevice so that it is sticking out between the side panel and the screen.
    • Be gentle when popping the panel off.
  2. LG G Pad 8.3 4G Back Panel Replacement: passo 2, immagine 1 di 3 LG G Pad 8.3 4G Back Panel Replacement: passo 2, immagine 2 di 3 LG G Pad 8.3 4G Back Panel Replacement: passo 2, immagine 3 di 3
    • Take the spudger and slide it around the perimeter of the device.
    • Pull gently on the edges to get the panel to pop up.
    • If the panel does not budge, be aware that there is adhesive on the back of the battery holding the back shut. Make sure to just move around the perimeter of the back panel until the panel is able to lift forward.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 21
Tutti i Tempi: 416
