Introduzione
If your LG Fortune’s camera has begun degrade a little bit and is not taking pictures as well as it should, or has, then use this guide to replace your camera
Cosa ti serve
Use the slit on the bottom right side of the phone to open the back cover of your phone.
Slowly pry the back cover off the phone starting from the bottom up to the top.
Using a PH000 screwdriver, remove the ten 4mm screws on the back panelling.
Remove the back panelling from the device with your fingers or a spudger.
Work slowly side to side to release this back casing and expose the motherboard.
Unplug the camera from the phone using a metal spudger to get underneath the tape and remove the camera.
