Introduzione
If you have a bad motherboard or are using it for parts this guide with show you how to retrieve the motherboard from your LG Fortune phone.
Cosa ti serve
Use the slit on the bottom right side of the phone to open the back cover of your phone.
Slowly pry the back cover off the phone starting from the bottom up to the top.
Using a PH000 screwdriver, remove the ten 4mm screws on the back panelling.
Remove the back panelling from the device with your fingers or a spudger.
Work slowly side to side to release this back casing and expose the motherboard.
