Introduzione
A camera in a device captures moments and memories, but with extensive use, the camera component may encounter issues or stop functioning properly. If you've noticed blurry images, black screens, or error messages when trying to access your camera, it could indicate a problem with the camera module itself.
In this guide, we'll walk you through the steps to safely remove and replace the camera in the LG Enact. This guide will help you address potential camera-related issues. Remember to power off your device before starting the camera replacement process to ensure a safe and effective procedure.
Cosa ti serve
Open the back cover by prying into the bottom tab with an iFixit opening tool.
Remove the three 1.2 mm screws from the speaker using a Phillips #00 screwdriver.
Remove the nine 1.2 mm screws from the midframe using a Phillips #00 screwdriver.
