Introduzione
If the camera button or the volume buttons on your LG EnV Touch VX11000 are jammed, stuck, or unresponsive, you may need to replace them. This guide will show you how to replace the camera and volume buttons on an LG EnV Touch VX11000.
Parti
Nessuna parte richiesta.
Turn the phone off.
  • Turn the phone off.
  • Flip it over so the front screen is facing down.
Aggiungi Commento
Slide the release latch down and toward you while lifting up on the left side of the battery cover.
  • Slide the release latch down and toward you while lifting up on the left side of the battery cover.
Aggiungi Commento
  • Lift the edge of the battery to remove it.
Aggiungi Commento
  • Locate the three screw covers on the back of the phone. Using your fingernail (or a spudger, pry off screw covers.
  • Using a Phillips #000 Screwdriver, remove the 1.5mm #000 Phillips screws that were under the screw covers.
Aggiungi Commento
  • Locate the two inner 1.5mm #000 Phillips screws and remove them using a Phillips #000 screwdriver.
Aggiungi Commento
  • Use a plastic opening tool or your fingernail to pry off the back case.
  • The camera and volume keys will fall off.
Aggiungi Commento
Conclusione
Rachel Smith
Membro da: 30/09/2013
578 Reputazione
5 Guide realizzate
Cal Poly, Team 13-2, Forte Fall 2013 Membro di Cal Poly, Team 13-2, Forte Fall 2013
CPSU-FORTE-F13S13G2
4 Membri
10 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 168
