Introduzione
If the screen on your LG EnV Touch VX11000 is cracked, scratched, or not displaying properly, you may need to replace it. This guide will show you how to replace the screen assembly on an LG EnV Touch VX11000.
Cosa ti serve
Locate the three screw covers on the back of the phone. Using your fingernail (or a spudger, pry off screw covers.
Using a Phillips #000 Screwdriver, remove the 1.5mm #000 Phillips screws that were under the screw covers.
Locate the two 1.5mm #000 Phillips screws on the outside of each hinge.
Remove the two 1.5mm #000 Phillips screws with a Phillips #000 screwdriver.
Altre 3 persone hanno completato questa guida.
