Salta al contenuto principale
LG EnV Touch VX11000 Screen Assembly Replacement
Cosa ti serve
  1. LG EnV Touch VX11000 Screen Assembly Replacement, Battery: passo 1, immagine 1 di 1
    • Turn the phone off.
    • Flip it over so the front screen is facing down.
  2. LG EnV Touch VX11000 Screen Assembly Replacement: passo 2, immagine 1 di 1
    • Slide the release latch down and toward you while lifting up on the left side of the battery cover.
  3. LG EnV Touch VX11000 Screen Assembly Replacement: passo 3, immagine 1 di 2 LG EnV Touch VX11000 Screen Assembly Replacement: passo 3, immagine 2 di 2
    • Lift the edge of the battery to remove it.
  4. LG EnV Touch VX11000 Screen Assembly Replacement, Volume and Camera Buttons: passo 4, immagine 1 di 2 LG EnV Touch VX11000 Screen Assembly Replacement, Volume and Camera Buttons: passo 4, immagine 2 di 2
    • Locate the three screw covers on the back of the phone. Using your fingernail (or a spudger, pry off screw covers.
    • Using a Phillips #000 Screwdriver, remove the 1.5mm #000 Phillips screws that were under the screw covers.
  5. LG EnV Touch VX11000 Screen Assembly Replacement: passo 5, immagine 1 di 1
    • Locate the two inner 1.5mm #000 Phillips screws and remove them using a Phillips #000 screwdriver.
  6. LG EnV Touch VX11000 Screen Assembly Replacement: passo 6, immagine 1 di 2 LG EnV Touch VX11000 Screen Assembly Replacement: passo 6, immagine 2 di 2
    • Use a plastic opening tool or your fingernail to pry off the back case.
    • The camera and volume keys will fall off.
  7. LG EnV Touch VX11000 Screen Assembly Replacement, Screen Assembly: passo 7, immagine 1 di 3 LG EnV Touch VX11000 Screen Assembly Replacement, Screen Assembly: passo 7, immagine 2 di 3 LG EnV Touch VX11000 Screen Assembly Replacement, Screen Assembly: passo 7, immagine 3 di 3
    • Open the phone at a 90 degree angle. This needs to be done in order to reach the screws.
    • Locate the two 1.5mm #000 Phillips screws on the outside of each hinge.
    • Remove the two 1.5mm #000 Phillips screws with a Phillips #000 screwdriver.
  8. LG EnV Touch VX11000 Screen Assembly Replacement: passo 8, immagine 1 di 2 LG EnV Touch VX11000 Screen Assembly Replacement: passo 8, immagine 2 di 2
    • Pry off the two screw covers on the inside screen, using a spudger or your fingernail.
    • Remove the two 1.5mm #000 Phillips screws that were under the screw covers using the Phillips #000 screwdriver.
  9. LG EnV Touch VX11000 Screen Assembly Replacement: passo 9, immagine 1 di 2 LG EnV Touch VX11000 Screen Assembly Replacement: passo 9, immagine 2 di 2
    • Pry off the front frame using your fingernail.
    • The frame should still be connected to the rest of the phone by the orange tab.
  10. LG EnV Touch VX11000 Screen Assembly Replacement: passo 10, immagine 1 di 1
    • Remove the four 1.5mm #000 Phillips screws at each of the corners of the phone, using the Phillips #000 screwdriver.
  11. LG EnV Touch VX11000 Screen Assembly Replacement: passo 11, immagine 1 di 3 LG EnV Touch VX11000 Screen Assembly Replacement: passo 11, immagine 2 di 3 LG EnV Touch VX11000 Screen Assembly Replacement: passo 11, immagine 3 di 3
    • Peel off the gold tape.
    • Gently pry up the metal frame with your fingers so that the screen can be removed.
  12. LG EnV Touch VX11000 Screen Assembly Replacement: passo 12, immagine 1 di 2 LG EnV Touch VX11000 Screen Assembly Replacement: passo 12, immagine 2 di 2
    • Unplug the connector from the screen.
Conclusione
Altre 3 persone hanno completato questa guida.
Rachel Smith
Membro da: 09/30/13
593 Reputazione
5 Guide realizzate
Cal Poly, Team 13-2, Forte Fall 2013 Membro di Cal Poly, Team 13-2, Forte Fall 2013
CPSU-FORTE-F13S13G2
4 Membri
10 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 14
Tutti i Tempi: 1,301
