Salta al contenuto principale
LG EnV Touch VX11000 Keyboard Replacement
Cosa ti serve
  1. LG EnV Touch VX11000 Keyboard Replacement, Battery: passo 1, immagine 1 di 1
    • Turn the phone off.
    • Flip it over so the front screen is facing down.
  2. LG EnV Touch VX11000 Keyboard Replacement: passo 2, immagine 1 di 1
    • Slide the release latch down and toward you while lifting up on the left side of the battery cover.
  3. LG EnV Touch VX11000 Keyboard Replacement: passo 3, immagine 1 di 2 LG EnV Touch VX11000 Keyboard Replacement: passo 3, immagine 2 di 2
    • Lift the edge of the battery to remove it.
  4. LG EnV Touch VX11000 Keyboard Replacement, Volume and Camera Buttons: passo 4, immagine 1 di 2 LG EnV Touch VX11000 Keyboard Replacement, Volume and Camera Buttons: passo 4, immagine 2 di 2
    • Locate the three screw covers on the back of the phone. Using your fingernail (or a spudger, pry off screw covers.
    • Using a Phillips #000 Screwdriver, remove the 1.5mm #000 Phillips screws that were under the screw covers.
  5. LG EnV Touch VX11000 Keyboard Replacement: passo 5, immagine 1 di 1
    • Locate the two inner 1.5mm #000 Phillips screws and remove them using a Phillips #000 screwdriver.
  6. LG EnV Touch VX11000 Keyboard Replacement: passo 6, immagine 1 di 2 LG EnV Touch VX11000 Keyboard Replacement: passo 6, immagine 2 di 2
    • Use a plastic opening tool or your fingernail to pry off the back case.
    • The camera and volume keys will fall off.
  7. LG EnV Touch VX11000 Keyboard Replacement, Keyboard: passo 7, immagine 1 di 1
    • Use your hands to open the phone, separating the keyboard frame from the screen.
    • Using your thumbs, gently separate the motherboard from the frame, and the keyboard will fall out.
Conclusione
Rachel Smith
Membro da: 09/30/13
593 Reputazione
5 Guide realizzate
Cal Poly, Team 13-2, Forte Fall 2013 Membro di Cal Poly, Team 13-2, Forte Fall 2013
CPSU-FORTE-F13S13G2
4 Membri
10 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 521
