Salta al contenuto principale
LG Cosmos 2 QWERTY Keyboard Replacement
Cosa ti serve
  1. LG Cosmos 2 QWERTY Keyboard Replacement, Battery: passo 1, immagine 1 di 3 LG Cosmos 2 QWERTY Keyboard Replacement, Battery: passo 1, immagine 2 di 3 LG Cosmos 2 QWERTY Keyboard Replacement, Battery: passo 1, immagine 3 di 3
    • Insert the plastic opener into the slot at the top of the device.
    • Apply gentle pressure with the plastic tool to pop the back case off.
  2. LG Cosmos 2 QWERTY Keyboard Replacement: passo 2, immagine 1 di 3 LG Cosmos 2 QWERTY Keyboard Replacement: passo 2, immagine 2 di 3 LG Cosmos 2 QWERTY Keyboard Replacement: passo 2, immagine 3 di 3
    • Use the plastic opener to lift, and remove, the device battery.
  3. LG Cosmos 2 QWERTY Keyboard Replacement, Rear Case: passo 3, immagine 1 di 1
    • Use a screwdriver and corresponding bit to remove the six 2mm screws that are located along the edge of the rear case. Set the screws aside.
  4. LG Cosmos 2 QWERTY Keyboard Replacement: passo 4, immagine 1 di 3 LG Cosmos 2 QWERTY Keyboard Replacement: passo 4, immagine 2 di 3 LG Cosmos 2 QWERTY Keyboard Replacement: passo 4, immagine 3 di 3
    • Use the plastic opener to pry the rear case loose.
    • This can be difficult. You will need to pry around the entire edge of the rear case, not just in one place.
  5. LG Cosmos 2 QWERTY Keyboard Replacement, Motherboard: passo 5, immagine 1 di 1
    • Use a screwdriver and corresponding bit to remove the two 3mm screws that attach the motherboard to the front case. Set the screws aside
  6. LG Cosmos 2 QWERTY Keyboard Replacement: passo 6, immagine 1 di 1
    • Rotate the phone 180 degrees and use the plastic opener to lift the metal piece that covers the ribbon cable.
  7. LG Cosmos 2 QWERTY Keyboard Replacement: passo 7, immagine 1 di 2 LG Cosmos 2 QWERTY Keyboard Replacement: passo 7, immagine 2 di 2
    • Use the plastic opener to disconnect the ribbon cable.
  8. LG Cosmos 2 QWERTY Keyboard Replacement: passo 8, immagine 1 di 2 LG Cosmos 2 QWERTY Keyboard Replacement: passo 8, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Use tweezers to disconnect the two cables that attach the motherboard to the case.
    • Note: Pull on the cables gently to prevent damage for future use.
  9. LG Cosmos 2 QWERTY Keyboard Replacement: passo 9, immagine 1 di 1
    • Remove the motherboard from the front case.
  10. LG Cosmos 2 QWERTY Keyboard Replacement, QWERTY Keyboard: passo 10, immagine 1 di 1
    • Flip the front case over. If the keyboard doesn't fall out, push it through the front case.
Conclusione
Nick White
Membro da: 10/18/13
866 Reputazione
8 Guide realizzate
Clemson, Team 13-1, Benson Fall 2013 Membro di Clemson, Team 13-1, Benson Fall 2013
CLEM-BENSON-F13S13G1
3 Membri
16 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 493
