Salta al contenuto principale
LG Chocolate Side Buttons Replacement
Cosa ti serve
  1. LG Chocolate Side Buttons Replacement, Battery: passo 1, immagine 1 di 2 LG Chocolate Side Buttons Replacement, Battery: passo 1, immagine 2 di 2
    • Find a sliding button on the lower back side of the device and with your finger, slide it to the left firmly.
    • The battery should pop out fairly easily. If not, slide the button further or grab and pull it while sliding the button.
  2. LG Chocolate Side Buttons Replacement, Back Cover: passo 2, immagine 1 di 1
    • Use a Phillips #00 screwdriver to unscrew the four Phillips #00 screws on the four corners under the battery to unfasten the back case from the phone.
  3. LG Chocolate Side Buttons Replacement: passo 3, immagine 1 di 3 LG Chocolate Side Buttons Replacement: passo 3, immagine 2 di 3 LG Chocolate Side Buttons Replacement: passo 3, immagine 3 di 3
    • Take the case off by using a plastic opening tool.
    • Continue using the plastic opening tool around the sides of the device, unhooking the eight tabs securing the back cover to the rest of the phone as shown in the second photo.
    • The back speaker will be connected to the motherboard, and must be disconnected to remove the case.
  4. LG Chocolate Side Buttons Replacement, Sliding Front: passo 4, immagine 1 di 1
    • Unscrew the 4 Phillips 00 screws that connect the two halves of the phone together.
  5. LG Chocolate Side Buttons Replacement: passo 5, immagine 1 di 2 LG Chocolate Side Buttons Replacement: passo 5, immagine 2 di 2
    • Between the two halves is a ribbon. Use a plastic opening tool to flip up the lock and disconnect it.
  6. LG Chocolate Side Buttons Replacement: passo 6, immagine 1 di 2 LG Chocolate Side Buttons Replacement: passo 6, immagine 2 di 2
    • Pry off the plastic tabs that cover two screws, as shown in the first picture.
    • Then, remove the 6 Phillips 00 screws from the back of the case, as shown in the second picture.
  7. LG Chocolate Side Buttons Replacement: passo 7, immagine 1 di 1
    • Pry off the back cover from the front of the case using a plastic opening tool.
  8. LG Chocolate Side Buttons Replacement, LCD Board: passo 8, immagine 1 di 3 LG Chocolate Side Buttons Replacement, LCD Board: passo 8, immagine 2 di 3 LG Chocolate Side Buttons Replacement, LCD Board: passo 8, immagine 3 di 3
    • Pry the front speaker and wireless receiver out of the front case using a spudger.
    • They may be taped into the case, so don't be afraid to pry hard.
  9. LG Chocolate Side Buttons Replacement: passo 9, immagine 1 di 2 LG Chocolate Side Buttons Replacement: passo 9, immagine 2 di 2
    • Starting with the side that has the speaker and receiver, carefully lift the LCD Board out of the case.
  10. LG Chocolate Side Buttons Replacement: passo 10, immagine 1 di 1
    • Unhook the ribbon cable using that flat side of a spudger.
  11. LG Chocolate Side Buttons Replacement: passo 11, immagine 1 di 1
    • Next, carefully remove the tape from the LCD board.
  12. LG Chocolate Side Buttons Replacement: passo 12, immagine 1 di 2 LG Chocolate Side Buttons Replacement: passo 12, immagine 2 di 2
    • Finally, flip up the black switch to unhook the LCD screen from the LCD board using a spudger.
    • The LCD Board in now accessible.
  13. LG Chocolate Side Buttons Replacement, Side Buttons: passo 13, immagine 1 di 1
    • The side buttons can now be accessed freely.
Conclusione
Charles Yoon
Membro da: 01/18/13
64 Reputazione
2 Guide realizzate
Cal Poly, Team 19-46, Regan Winter 2013 Membro di Cal Poly, Team 19-46, Regan Winter 2013
CPSU-REGAN-W13S19G46
4 Membri
22 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 189
